Stair treads not showing in section
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-12-17
11:12 PM
2023-05-09
03:09 PM
Rubia Torres
Hello guys, i need some help with this stair.Why i can't make the treads visible in a section, they are only showing when i select the stair.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-17 11:35 PM
Have a look at which Model View Option you have selected. You can control the visibility of the various elements of stairs (and other construction elements) in Model View Options. It should be location under the ‘Document’ menu or using the Quick Options bar at the bottom of the main window.
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-17 11:38 PM
This is for Archicad 26, I’m not sure which version you are using but it should be relatively the same.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-18 12:22 AM
I'm using Archicad 25.In Model View Option, Stair 3D and Section is set on Full when i set it to Schematic the treads appear in the section but in 3D it looks strange.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-18 09:26 AM
Your 3D window and section window will likely have difference Model View Options associated with them. Make sure they’re both set to full and make sure the tick box options for treads are turned on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-18 02:31 PM
Everything seems to be fine but the treads are still not showing 😕
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-19 07:57 AM
It’s not a scale sensitivity issue is it? I’ll have to open Archicad and have a look.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-19 08:16 AM
Could it be renovation filters?
I always blame them for everything!
Your treads can have a different renovation status to the rest of the stair.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-21 12:16 PM
I've tried different scales but it stays the same..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-12-21 12:18 PM
I've changed the renovation status of the stair nothing happened, i didn't know that the treads have different renovation status, how can i change only the renovation status of the treads ?
