Hi All,
I have been given a DWG survey file of a very large site. It has a heap of spot levels, but no contour lines. I was wondering if anyone knew of a fast way to add nodes for all the levels rather than individually adding the points using the mesh tool?
The surveyor also provided a 3D DWG file, but when I view the model in 3D it seems to be just elevated lifework rather than a mesh. So I figure it might be best to remodel it?
I'm using archicad 18. Any help on this would be most appreciated.
Walter
