Survey settings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2024-09-05 05:56 PM - last edited on 2024-09-09 10:23 AM by Laszlo Nagy
Hello, I have a question about how could I reset direction Y in Archicad 26 to have better accuracy when presenting the points in stereo? At the moment I have the symbol in this way and I would like to reverse it Y ul like the red arrow below.
Solved! Go to Solution.
- Labels:
Input Aids
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-09-05 06:02 PM
The symbol is showing like that because you have rotated your screen, the only way to get it back to the X, Y, in your sketch is to revert the screen rotation to '0'. Where you have 90º at the moment, click that and select '0' from the list. This will however rotate the entire content of your window.
You should import the survey data and then set the project origin using the Survey Point to indicate to Archicad where North is and also move the survey point so effectively reset Project '0' to be the co-ordinates of a known point in your survey.
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-09-05 06:02 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-09-05 06:25 PM
I have this problem with the Y coordinate because in the right north pozition I have negative value. Can you have a solution about this problem?
