Tags & Labelling Option not available
scottybaustralia1990
Hi There,
My work computer allows me to display the door size and has the tags & labelling option available in the hinged door settings for archicad 26, but when i load the same job with archicad 26 to my home computer the option disappears which means my plans dont display door sizes? im sure im missing something obvious here
Thanks
2 REPLIES 2
Lingwisyer
Guru
Check your libraries? Might be a custom object that you do not have loaded on your home computer.
NateLumen
I would also suggest you check your Model View Options. We have had issues with a Model View Option set getting "unlinked" from a drawing or view - it shows up as "Missing" in the view settings, usually when MVO's have been changed by another user in a teamwork file. You would just need to go into the view settings and reselect the missing MVO. Might not be your issue, but worth checking.
