Yes it may depend if you have modelled the wall left to right or right to left.
You can invert the direction of the wall - it will not affect openings or trims.
But should affect the material placement.
If that doesn't work then you can select all walls in 3D and 'Align 3D Texture' and that should set all walls to use the same origin point for the texture.
