Read more
Trimming A Circle
Hello, Hope everyone is doing well!
I'm posting this to ask how can I trim a circle. I tried using the trim command as well the (command-click) but for some reason the trim is not working. I have a circle wall with another straight wall crossing in the circle. I want to trim one side of the circle, so that the wall ends up with one straight edge and the other is a curved wall. I attached a pic to make it clearer.
Thank you.
4 REPLIES 4
Eduardo Rolon
Cmd+click should work though you would need to do it in 2 steps
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
or you could use the Split command by selecting the circle and go Edit->Reshape->Split, click on the wall, select the side you want to erase and hit delete.
Sounds like a lot of steps but is fast
AC27 US/INT -> AC08
another Moderator
Your circle may be grouped. If it is, Suspend groups then you will be able to trim using Command Click method.
It worked. Thank you
