2012-02-09 08:37 PM - last edited on 2023-05-23 04:38 PM by Rubia Torres
2012-02-09 09:07 PM
2012-02-09 09:56 PM
2012-02-09 11:15 PM
2012-02-10 04:49 AM
2012-02-10 11:51 AM
s2art wrote:There is still a problem if the previous version of the object has already been used. If you save over an existing object, a new object with a new unique ID is created. Even though it has the same name as the previous object, ArchiCAD will see them as different because the hidden unique ID doesn't match. Any instances of the previous object placed in the floor plan will show as blobs, and reloading the library won't fit that. You either need to recover the old object or replace every instance of the old object with the new one.
You should be able to override the old object. Reload your Libraries after changing it to make sure the most current object is being used.
