WALLS - "Home Story only" and "All Relevant Stories"
rob2218
three questions:
1. why can't we simply "select a story" where we want to see the wall?
2. Why is it that if there are walls with parameters such as "home story only" and other walls that have the parameter "All Relevant Stories"...and I do a CTRL-A while I have the wall tool active...why can I NOT move "ALL" the selected walls to the "Home Story Only" parameter?
3. Someone, please explain what does "Relevant Stories Only" mean?
I'm assuming that it means if a wall is 2 stories tall for example...and this parameter of "All relevant stories" is set...then you will see that wall on both it's home story AND the story where it extends up to? is this correct? Cause sometimes these walls don't behave as such.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
21 REPLIES 21
Steve Jepson
rob2218 wrote:
By the way Steve....do you know of a way to have two planes intersect one another "AND" show that line where the two planes intersect? I don't mean "trim" either....why is it that when two planes intersect "thru" each other...they can't seem to generate that actual line where the fold occurs?
That is sometimes just a matter of the view angle or the sun angle.
What I don't like is that object that are well below the surface of the roof like rafters or something still show through.
Steve Jepson
No. But it bothers me too. For example in elevation there should be an line at the intersect of the roofs even if they are not trimmed.
Erich
Steve,
I run into this all the time and I agree, that line should not be there, but it is easy to get rid of, just pull your roof back 1/4" or so. Just enough to get the edge off the outer surface and the line goes away without the need of an SEO.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Steve Jepson
Erich wrote:
Steve,
Steve wrote:
My problem is that my gutters are walls/complex profiles so I am having a problem finding a way to show the gutters on the first floor roofs in the same plan view as the gutters for the second floor roofs.
If I explode the gutters into morphs I can have them display on all levels.
Is there some there way to do this?
There ought to be some way to show walls and/or complex profiles on all levels.
Steve, there is another easy way of achieving this. Just go to the Floor Plan Cut Plane Settings Dialog and adjust the Offset value of the lower limit of the Floor Plan Range so that it includes the gutter vertically. Then it will appear on the upper story as well.
Steve Jepson
If we could set a different cut plane for each View then that might work in some situations. I was not aware that this could be done. Othewise, no. Changing the cut plane affects too many other things like line types...
Saved Views store the current Floor Plan Cut Plane Settings.
Steve Jepson
Thanks Laszlo,
It does change the line types for what is displayed above and below the cut plane which is not always convienient to change for the sake of a different cut plane.
I would still like to be able to display walls on All Stories as we can do with beams, shells, slabs, mesh, morphs...
My main reaons for wanting this is because none of those things is only what they are called. I model all sorts fo things with walls. Things I would like to see on all stories and control visibility with layers.
I would like to know what reason is there to restrict walls from having a Show on All Stroies option. How is it useful to restric the dispaly of walls that way?
Yes, I am with you on that.
I would like to have the ability to display all elements types on any combination of Stories I specify and also have the ability to specify what attributes (fills, line types, pens) the given element is displayed with on any of those stories. Something like an optional per story or per story range 2d display setting.
Steve Jepson
So do you think it is some kind of oversight that walls can not be displayed on all stories or is it intentional for some special purpose ?
