Wall gap problem
renatolemus
Hello everyone. I'm trying to get rid of this weird gap at the intersection of walls.
I have tried to fix it intersecting both walls, changing the alignment, change layers, etc.
But, can´t solve this issue.
I'm using Archicad 25
thanks in advance
Make all layers visible to show this hidden element may be a column.
AC 28 INT 5200/WIN 11
You're right. My bad... It was a hidden wall...
thank you sir
You’re welcome @renatolemus, BR.
