Wall intersection methods
Strawbale23
Hi, just wondering if there is a way to create a wall that doesn't interact in anyway with other walls?
I know you can do it with a layer settings, but just wondering if there is another way to do it .
Thanks
AC26
https://www.zendsign.fr/
Mahmoud Qenawi
Other than layers settings :
1) you can adjust walls to meet at the edges away from reference lines.
2) you can use polygonal wall also.
AC 25 INT 3002
DGSketcher
Champion
Make sure the baselines don't connect, although this doesn't always work. The only other way I know is a forced drafting error where you leave a tiny gap that won't show in dimensions or drawings.
Apple iMac macOS Ventura / AC26UKI (most recent builds)
