If you have to use an open hatch then I would probably use one that rotates with the wall (element origin) so at least it is consistent in relation to the wall.
Yes they will all rotate in different directions on plan but it will always be a 45° hatch in that wall.
You either have to have a fill that is consistent across the entire plan (project origin) or is aligned to each element (element origin).
The only fills that can do both at the same time are empty, solid and % fills.
