Weird 3D window issue
Arcadia
The attached screenshot shows that my glass balustrade with transparency enabled is for some reason 'blocking' the texture on my 'water' (just a slab object with water texture). This doesn't affect any documentation but it is a little annoying. Anyone know a quick fix?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
Steve Jepson
what happens if you adjust the view just slightly? Did you try to regenerate?
Arcadia
As I rotate the view around the glass always is blocking only the portion of the texture it is in front of so it is not a regeneration issue. The only way I can fix the issue is to change the dsiplay of the layer the balustrading is on to wire frame.
Ingolf
The Glass Ballustrade gives you some headache I see....
As I glimpse, it seems to me that you have made the water in your pool from Thin slabs with the image of the bottom of a pool as material? Am I right?
I would have tried to change the upper slab (in the water of the pool) to plain water (or glass) and see what happens.
Best whishes!
Ingolf
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
