Read more
Why is there a stair finish in CORE ONLY?
LeeJaeYoung
Q4. Why is there a stair finish in CORE ONLY?
AC27 on window 11
11 REPLIES 11
1. You made me switch from End Riser to End Tread.
2. So I have to use SOE.
3. And adding an if statement seems to be a better solution than adding an if statement to the profile.
AC27 on window 11
Your answer raised a question about 2D.
If possible, we would appreciate it if you could check the questions below.
https://community.Graphisoft.com/t5/Design-forum/I-want-to-erase-the-lines-on-both-sides-of-the-last... M161761
AC27 on window 11
