Why isn't it possible to offset a circle or an ellipse as a copy?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-02-09 03:55 PM
‎2021-02-09
03:55 PM
I am very new to ArchiCAD and this community.
That's why my question is very simple. In case of complex poly lines or rectangles and so on it is very easy to offset this lines as a copy. Why doesn't it work with circles and ellipses? Am I doing something wrong? It's quite a simple task for such a program. It should be there somewhere but I can't find it...???
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-02-10 02:05 AM
‎2021-02-10
02:05 AM
You mean when you start to drag a line and then you activate a copy?
If so, that is not truly offsetting the line.
But I don't think that is what you mean anyway.
Using the offset edge option in the pet palette is going to give an offset .
If this is what you are using then as you would have noticed the circle/ellipse does not have this option.
Why that is so I can not say.
You can however use the offset tool.
Select the tool you want to draw with.
Activate the offset tool and then magic wand on the element/s you want to offset.
Using this you can offset lines from walls or wall from lines (including circles).
I also moved your post as it did not belong in the 'Archicad +' section as that is for discussions about Archicad.
Pleas try to post in a relevant section or you may find your post just gets moved by a moderator.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-02-10 03:53 PM
‎2021-02-10
03:53 PM
You can't offset circles or elipses as a line but you can offset them as a fill.
While you're using 'Offset all edges' press 'Ctrl' or 'Cmd' for one offset copy or 'Ctrl-Alt' or 'Cmd-Alt' for multiple offset copies.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
ArchiCAD 25.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-02-10 05:35 PM
‎2021-02-10
05:35 PM
This also bugs me. But there is a very weird workaround:
"Open" the circle with the pet palette, offset it (it works now, if the circle is just an arc!), close it again.
Very crude, to say the least.
Hopefully GS will address this with 25.
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-02-11 03:18 AM
‎2021-02-11
03:18 AM
Very crude, to say the least.![]()
You can also copy the circle, paste the circle and then stretch the copy.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-02-18 08:02 PM
‎2021-02-18
08:02 PM
Barry wrote:Thank you for the answer. Yes, actually it was what I meant. Still can't get used to the different approach in comparison to AutoCAD...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-02-18 08:03 PM
‎2021-02-18
08:03 PM
Dontknow wrote:Wow, that's cool! Thank you! That is very good to know.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-02-18 08:04 PM
‎2021-02-18
08:04 PM
runxel wrote:I hope that too! Thanks for the answer!
