2022-01-12 07:03 AM
Element ID , plan view, elevation, width, height etc won't show up in my schedules
even though they are selected in scheme settings.
Solved! Go to Solution.
2022-01-19 01:59 AM - edited 2022-01-19 02:00 AM
Are your Windows classified as Windows?
Your Schedule Criteria says:
"Archicad Classification" is in branch of "Window"
which means that your Windows must be classified as Windows to appear on the Schedule.
2022-01-19 03:32 AM - last edited on 2022-01-19 03:37 AM by Laszlo Nagy
Hi Laszlo. Yes that worked. I switched from V20 to V24 last year so
hadn't encountered this change before. My other job where it was working was an earlier V20 brought into V24. Thank you.
2022-01-12 08:42 AM - edited 2022-01-12 08:42 AM
check your scheme settings if you are choosing the correct element type.
2022-01-12 09:16 AM
Also check if the have a category for properties.
2022-01-12 09:26 AM
2022-01-12 10:08 AM
But are the widows categorized or just undefined? When mine are undefined they don't populate in the schedule
2022-01-12 11:34 AM
in my opinion simplest way of setting up the window schedule
2022-01-12 11:37 AM
My objective is to create a wall and door schedule that I can see the I.D views of the windows or doors quantity, head heights etc
2022-01-12 01:50 PM
Thanks for that but sorry I don't understand where to change categorised of undefined.
2022-01-13 03:19 AM
i haven't tried merging the wall and door & window in one scheme though. but if you are referring to something like this?
2022-01-13 05:57 AM
They are not in one scheme. The tow schedules are just placed on one sheet a they both fit. I still can't work out what is wrong but.
