Windows and glass position
I want to put in windows that have the glass located 1" from the frame instead of centered in the frame. Is there a window object in Archicad that can do this or do I have to create a new object?
Thanks for any help,
MIchele
David Larrew
Have you tried the "W Curtain Wall Straight" window object? I think it allows you to set the glass panel setback. I must admit that I don't use the standard AC default doors and windows.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Storefront Window has this parameter, Glass setback. But Unfortunately, it's not a hotspot.
