This is not possible to do as you described it.
If you want to have the drawing info of each related Interior Elevation and the Floor Plan in one view then you should create these Interior Elevations, then place them plus the floor plan on a Layout, then use that Layout as a Trace Reference in the viewpoint you are working.
This way you will see all those other views.
