2004-07-17 02:01 AM
2004-07-17 05:17 AM
2004-07-19 07:38 PM
2004-07-19 08:51 PM
2004-07-20 02:33 AM
2004-07-20 06:26 AM
lsid wrote:Some comments before your questions. Align View will only work "perfectly" with a non-distorted image. Lens distortion is the greatest with wide-angle lenses. If the lens is mapping photons 1 to 1 onto the film or digital sensor, the distortion is the least (and almost undetectable with good lenses). The wider the angle, the greater the distortion ... to the point where lines will start to bend into curves if you draw a straight line against them.
thanks for your response which helps alot....so here is the new additions to the existing house. I have been tweaking with the camera setting for awhile and this is what i came out with.
1. at the back , the roof is tilted up and i can't bring it align with the photo roof.
2. can i have the photorender image in transparency?
3. how can i bring the image(photo) to the centre?
2004-07-20 06:23 PM
(It would be great if the OpenGL window in AC would show the background image!)If you use the internal engine and set the the 3D window to wire frame. That should let you move around pretty quickly to get closer. Be sure to set the 3D window size the same as your image.
2004-07-20 09:16 PM
2004-07-21 06:03 AM
lsid wrote:Good.
thank you so much for all your help.....still digesting the tips but meanwhile, i got to play with the multi layer, smudge, distort and skew tools in PS ...it's fun!
