another stair problem
can i built this stair from the stair maker in one peace? its not a supported shape. how am i supposed to create it?
7 REPLIES 7
fuzzytnth3
You can use fills to draw a custom stair.
Just draw a fill that shows the outline of the stair in plan and add a 2d line to show the direction of travel.
From the Design menu select the command "Create stair using selection" the Stairmaker interface will appear and you then set the riser height etc. Save the stair in your Projects Object library and you are done
See attached screenshot
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
i cannot believe it!!!!
thats an amazing option!! it was there in version 9 too? its fantastic!
but still this stair seems to have a problem
take a look at the error message
I have not worked with this option for a long time, but maybe the width of all flights are supposed to be equal? I am just guessing.
Djordje
Ace
Your travel line should not be a polyline, but a group of lines. Its ends have to touch the edges of the stairs polygon. Each kink in the travel line is a landing/turn.
Try ArchiStair, too ... by Cigraph.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
yes you are right about the polyline
but still i did it with line and i enabled the group thing from the control box and then i had another problem
I just created a custom stairway where I am trying to place a tall wall on the outside of the stairway that follows the stairway down. Any ideas?
you need to place a wall taller than the whole stair. and then
Design > Solid Element Operation
1) Select the Stair and make it the operator,
2) Select the wall and click on the target object button.
3) Action - Subtract with upward extrusion
4) execute
i hope it works. i just did it!
