background grid
alemanda
Is there a way to switch off by default the visibility of the grid in all the views in Archicad? Some registry key, some option?
Thanks
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
6 REPLIES 6
vistasp
Can't you just turn it off in your template alemanda?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Link
AFAIK the only way is manually going to every single window and turning it off. A keyboard shortcut helps!
There's no global switch for this that I know of. Wish there was!
Link.
alemanda
How?! This is exactly what I try to achieve. Thanks for any help.
Win 10 Pro 64bit
www.almadw.it
Erwin Edel
Quick and dirty fix: view > grid & editing plane options > grids & background
Change both colours to be the same. Grid is still there, you just don't see it.
Other option, open a view, go to view > grid display.
If you do this in the template, any new project based on the template will have grids off.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
alemanda
How? How to save this option in the template?
I tried (and probably made a mistake), but anytime I open a detail, worksheet, new section ... the grid is always there!
Doesn't anybody know how to disable by the default when launching archicad?
Win 10 Pro 64bit
www.almadw.it
Erwin Edel
Grid can be turned on and off for all views individually. You could have grid on in details and off in floorplans, for example. So open all different views and turn it off.
I never understood the problems with grid. My colleague hates it, for me it just gives a sense of the scale of things.
www.leloup.nl
Windows 10 Pro
