beam axis in Section & Elevation
amitchristian
Is there any possible way to show axis of beam in Section or Elevation view?
Beam axis becomes visible in plan view once turned ON from Bean settings and MVO. But its not visible in Section.
I need to show axis in section elevation for steel hollow sections. Placing 2D lines to represent axis is not accurate method.
Please review attached Plan & Section view screenshots and let me know if any solution.
Currently, this is not possible to do, all you could do is draw those Axis Lines manually in Section.
You should make a wish for this feature so we can submit it to Graphisoft.
If you do make a wish, please post it link here.
