door hidden by slab beam beneath
hello, the door is at 0.00 above slab, but it is hidden by the beam below 0.00 under the slab, why please? thanks
1 REPLY 1
Hello emailcopy,
You are able to change the display order of these elements (right clic on the wall with the door)
You can modify the hatch background of the beam to make it transparent.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
