ellipse in morph
How do you draw an ellipse on a 2d morph? I want to cut an ellipse in a 2d morph so that it can be extruded up to form a tub surround. I can create the ellipse with the arc tool then convert it into a morph. It would be nice to have the arc/ellipse tool available when drawing on the 2d morph surface. I don't want to use solid element operations and then have to move the hole every time I move it. One time I was able to get the two morphs to union and the ellipse subtracted out, but now I can't figure out how to duplicate what I did.
MrC
HI LOREN. MAYBE YOU CAN FIND A STANDARD TUB THAT WORKS FOR YOU HERE?
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
Hmooslechner
It is always possible to draw an normal ellipse with the normal circle-Tool in the 2D-windows.
There You can duplicate it with a Morph-Line - it will be segmented, bur You get a nearly ellipse-shape.
This thing - just the segments without the Morph-surface - you can put on any other Morph-Face and connect it with it - add it.
Something like this:
https://youtu.be/gKPTt3jejlY
