empty fill
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2003-11-17 11:07 PM
‎2003-11-17
11:07 PM
Thanks,
Michele
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-11-17 11:15 PM
‎2003-11-17
11:15 PM
The only way I have been able to do it is make the fill in AC7 and merge it into the version 8 file.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-11-17 11:34 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-11-18 10:55 AM
‎2003-11-18
10:55 AM
just a question to satisfy my curiosity -
how will your empty fill be different to the default empty fill?
also - i seem to have three 'empty' fills in my project at the moment;
• "Empty
• "Empty Fill"
• "cavity"
is this normal?
~/archiben
• "Empty
• "Empty Fill"
• "cavity"
is this normal?
~/archiben
b e n f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-11-18 12:40 PM
‎2003-11-18
12:40 PM
~/archiben wrote:The fills are different in name only. I use fills of the same type with different names when I want them to look the same but not clean up to each other in plan and or section.
• "Empty
• "Empty Fill"
• "cavity"
is this normal?
~/archiben
For example:
I use an empty fill called "!Section Fill" (the exclamation point is to put it at the top of the list) for all the frame construction (and trims) so that the elements all clean up in section to give me a nice clean empty outline. I use "Empty Fill" for the elements I like fixtures and cabinetry that I don't want to clean up to the building section.
The three empty fills you have are not the default (I assume that is what you mean by "normal"). By default in AC8 there is only one "Empty Fill".
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-11-18 02:57 PM
‎2003-11-18
02:57 PM
ah. they must have been inherited from historical versions of the project then . . .
and thanks for the lesson in empty fills. hadn't thought of using them like that!
~/archiben
~/archiben
b e n f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2003-11-20 12:17 PM
‎2003-11-20
12:17 PM
As said in the other thread:
To create an empty fill:
"Draw" a hotspot in ArchiCAD. Select it and copy it (to the clipboard with <ctrl>C)
Open the Fill type dialog box
- Create a new symbol fill
- Past in the hotspot.
- Set stroke X1 = 100 and Y2 = 100 (assuming mm)
- Set to Scale independent
- Edit the Bitmapped pattern
Done
HÃ¥kon Alm
ArchiCAD 8.0 R3 (Int) on Win XP SP1 (us)
P4, 2.8 GHz / ATI Radeon 9700 / Dual Hitachi 21 LCD screen
Done
HÃ¥kon Alm
