Hello m_aalaei,
The first solution is to create another layer to put it on it.
3D view
You can select all your project except the morph you do not want and do a right clic to select the option : "Show selection in 3D"
2D view
You can create a pen set or a graphics override to mask your morph by a white apparence on a white background. You can find these function by the menu "Documentation".
Either you can change the morph 2D parameters by modify these options :
By this last way you are able to mask a element which is above your cutting plane.
Christophe - FRANCEArchicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
