how to create custom panel ?
Hi every one i was wondering if there is anyway to create custom panel window as you see in image i tried to follow its instructions but i can not if anyone can guide that will be great
Thanks
4 REPLIES 4
Srinivas
Here's a tutorial on how to make it.
http://www.aecbytes.com/tipsandtricks/2006/issue4-archicad.html
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
clear explanation but shall i save it to specific folder inside archicad to be able to recall the object or i can save it in any drive any folder and i can call it also
THanks Srinivas,
Srinivas
Although you can save the library part anywhere, I would recommend saving it to the project specific library if you have any and make sure you load the library part to be able to use it.
ArchiCAD Services
iMac, Windows 10
Thanks Srinivas
