Read more
how to trim a curtain wall
hey i added a curtain wall to my design and i need to trim parts of it because it is higher than my wall level, and i have a slanted edge at the end of the wall so i need to match the curtain wall with it, how can i do that :s?
Always a pic or a screen shot could be helpful, however you can check in help for "connect to wall" option under Design > Curtain Wall > Connect Curtain Wall
and also you should consider SEO (Solid Element Operation )
w belhana wel shifa
edit the wall in 3D (if you select it, you'll see a button appear to do so)
you can then add/remove frames, change the overall boundary heigh/length etcetc.
