Read more
insert window in curve walls
another question pls...
I about to insert a window (or curtain wall) into a curve wall...
how can I insert windows along the curve wall that it can get its curve well? now it is straight !!!
thanx again
4 REPLIES 4
'W M-Curved 11' under 'Metal Windows' will curve with the wall. Change the material to suit. Unfortunately it doesn't have an openable sash.
'Curtain Wall Curved 11' will curve also, but you have to insert as a plain library part. Cut the hole in the wall with an empty opening if needed.
You may find the curtain wall parts are quite buggy and may not work 100%, but give it a try anyway!
thank u soo much...Peter
I didn`t find the "suit thing"....where can I change the mat to suit???
Sorry, I ment change the material of the window to what you require! eg wood!
muzedesigns
Would anyone be able to send me their w Curtain Wall Curved Object? The Australian Library does not have it included.
Thank you for your time!
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
