Ah - you are using schedules and not lists.
There is a difference.
With schedules I don't think you can do it with a marquee.
However you can select what you want to schedule in plan and then right click on the schedule and choose 'List Floor Plan Selection Only'.
But I don't know any way to automate this other than using extra criteria (i.e. key words in ID field or properties) and then filtering for those in the schedule criteria.
Basically you have to make one set of elements unique to the others so you can filter for them in the schedule settings.
