Read more
objects and stairs disapear on 3d window!
I'm designing a movie theatre where I have number of chairs and a staircase, that disapear while I'm working from the 3d. I cannot explain it. On the 3d I can highlight them and select the objects but i cannot see them if they are not selected. Any ideas?
I just realized that when I zoom in, and get close to my building, everything appears, when I zoom out, chairs and staircases disapear!
hmmm..
Hi LukasB,
Check you haven't set the 'Always display all elements located within the following radius' slider too low in the 3d window settings under openGL options, perhaps.
If this doesn't help, try just closing the 3d window and then turning it on again. Sometimes sorts out small glitches for me!
Hope that helps?
Pete.
Thanks Peter,
I didn't know about that setting...the problem was solved by itself though...I don't know how, I guess my computer was in a bad mood.
Thanks anyway though, that was a useful info.
lukas
