objects in plan do not show up in any other view (archicad)
Hi, I've placed objects in plan and the do not show up in any other view,
shower head-not visible at all in any other view except plan
basin- basin visible in all views but attached tap is not visible in any other views except plan
i've checked layers and gone through setting for hours, no one else in he office knows whats wrong with it either, please help!!
5 REPLIES 5
Probably Renovation Status of the uncooperative elements does not allow them to display in your other views... check the Reno setting for those views and that for the affected elements. (All assuming of course that each of your views has a named layer combination and not 'custom'.)
One of the forum moderators
Or is the a Model View Option that over-rides the display of fitting (plumbing) objects in elevations.
Just a guess as I don't use the defualt library but i know it has various over-ride options in the MVO.
David Maudlin
Look at Model View Options > Options for GDL Objects.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks, i'll try at work tomorrow, it's driving me nuts!
Thanks, this option has enabled my 3d + elevations 🙂
