Read more
show 2d elements in 3d view
is possible show the 2d elements in 3d view?
I need to insert in 3d model the cartography element as a basis (all in 2d - line or polyline), the cartography is in DWG format.
you have any ideas?
Import your .dwg file as GDL object. Then you can se your 2d contents in 3d view.
thank you very much....but I'm very novice of archicad world and I need the steps....if possible..
thank's
