slab is invisible?
hello, so I am currently just experimenting in archicad student and the other day I made a slab which was visible through the floor plan and 3D.
But today when I opened up the file, the slab was gone and was only an outline. It's still there in the floor plan but just not visible within the 3D view.
Any help is appreciated..
runxel
Ace
Either you used "Air" as BMat for the slab, or the slab layer is accidentally set to "wired" mode.
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
lol, just went through my layer settings and yeah it was in wired. thanks!!
