As Andro said, Solid Element Operations cannot be controlled or influenced by Renovation Filters.
Another tip for this situation:
Create the cut of the Slab into the Wall by using "Wall Niche Rectangular" objects all around the perimeter of the Slab. Then set the Reno Filter of these Wall Niche Rectangle Objects to "New".
There is also a parameter for the Wall Niche object using which you can hide its 2D so it does not mess up your Floor Plan.
With the "Existing" Reno Filters the Wall Niches then are not displayed, with the "New" they are and they cut the rectangular hole out of the Wall.
