Read more
some window wall returns not showing
some of the window wall returns are not showing. i have compared all the settings of those that are showing and those that aren't and they are identical. it isn't cutting plane. i've eyedroppered from one to another and it still won't show.
What are your window wall closure and also general settings parameters set to? Screen shot if possible. As a side note, it appears your window is malformed. I note the frame is outside of the wall thickness, what is going on there? Check your reveal settings and wall type (in the window settings).
Well, i just opened up the model to do you a screen shot, and i had an epiphany, and now i feel a fool. turned off ganging and all is well. it's off by default, but beware of favourites!
so sorry to bother you, live and learn.
wb
I seem to learn best from mistakes! No worries.
