Read more
stacked exterior walls
Ugljesa Janjic
Is it possible in ArchiCAD to make a stacked wall? I want to keep the same interior structure but change the exterior skins? Attached are a couple of Revit illustrations.
Ugljesa Janjic
ugljesa@janjicarch.com
ArchiCAD 25
Mac OS
Sure.
You can actually stack two different walls on top of each other but this is not the best option if you want to add doors and windows that span both walls (you'll need a window in one wall and an empty opening in the other).
The best solution is a Complex Profile wall that you create from fills in the profile Manager.
This will be one complete wall with as many parts as you need (in any shape as well).
You place it with the wall tool but have to switch the wall structure to use the complex profiles.
Doors and windows will interact just as they do with standard composite walls.
Ugljesa Janjic
Thanks, Barry. I will try that. I don't understand fully at this point, but it is a great pointer in which direction I should go. Thanks again and have a good day!
Ugljesa
Ugljesa Janjic
ArchiCAD 25
Mac OS
