stairs - section symbol
Bara3
I want to change symbol of section in my floor plan (you can see it in the picture). But even when I change stair section symbol in the stair settings nothing happens and the symbol stays the same (zigzag line). Do you have some advice what I am doing wrong? Thank you.
Thank you, so much I have tried to find it for a long time.
4 REPLIES 4
runxel
Legend
From the looks of it you're not actually editing the floorplan symbol, but the one for the RCP (reflected ceiling plan, which is determined by MVO).
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Thank you, yes, it it possible, please, where can I edit the floorplan symbol?
