viewing problems
I have recently moved from ArchiCad 9 to 13 and having problems viewing the composite elements, i.e. a cavity wall is shown on the drawing as blocks of colour and not hatched - brick hatching, cavity insulation, block hatching - all these are just blocks of colour?
I have set the background pen of the elements to 'transparent' but the colour blocks still show on my drawing, any advice would be appreciated, before all my hair has been pulled out.
Many thanks
Richard
Djordje
Ace
The default fills as well as the pens have changed between 9 and 13 ... check.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
David Maudlin
Richard:
One thing to check is Model View Options > Override Fill Display > Override Cut Fills.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David, thank you for the advice, yes that has worked.
Richard
