Read more
wall distances using tracker
hi there. I remember being able to type in wall length all of a sudden I cant and I cant figure out how to get it back. when I place a wall my reference doesn't start at 0,0 from where I click the refernce starts to where I am from 0,0 see example
I know the problem
Turn this off in you Work Environment
4 REPLIES 4
In the tracker settings, look to see if it is set to use relative coordinates.
thanks for reply. it still starts at say 9000 for example
I know the problem
legend! thanks mate appreciate it
