ā2023-01-31 11:14 AM - edited ā2023-01-31 11:33 AM
When I draw walls with rectangular, chained wall tools it creates separate walls not joint wall. How to fix it. Archicad 26
Solved! Go to Solution.
ā2023-01-31 01:15 PM
Try heading to the View Menu > On Screen View Options and checking the option Clean Wall & Beam Intersections on
ā2023-02-01 07:29 AM
1. Go to Windows Menu choose Toolbars -> choose Arrange Elements
2. On the Arrange Elements Toolbar activate Auto Group then every time you do a chained wall etc. it will automatically be grouped.
ā2023-02-01 10:27 AM
Thank you. I am just trying to follow the tutorials.
ā2023-01-31 11:40 AM
Check the layer intersection group number if it's assigned to 0 change it to any number other than 0.
ā2023-01-31 12:05 PM
I think all are set to 1, ā
ā2023-01-31 12:45 PM
That's because the thin skin at the composite edge I'm sure it's priority is higher than the rest, select the wall & check BM if higher then make it lower or duplicate and change the copy to be lower.
ā2023-01-31 01:25 PM
Thank you it solved joint problem but walls are still separate created.
ā
ā2023-02-01 02:09 AM - edited ā2023-02-01 03:15 AM
Toggle Groups (Alt + G)?
Though, given the nodes are black, it would appear that they are not grouped. You can create a group by making a selection then using the Create Group (Ctrl / Cmd + G) option.
ā2023-02-01 02:28 AM
That is it.
Rectangular and chained walls are in fact single walls that are grouped.
Turning the grouping on/off will allow you select individual walls or the group that was drawn with the rectangle or chained command.
