wall tools creates separated walls
StarBoy
When I draw walls with rectangular, chained wall tools it creates separate walls not joint wall. How to fix it. Archicad 26
3 ACCEPTED SOLUTIONS
Mscott
Try heading to the View Menu > On Screen View Options and checking the option Clean Wall & Beam Intersections on
ryejuan
1. Go to Windows Menu choose Toolbars -> choose Arrange Elements
2. On the Arrange Elements Toolbar activate Auto Group then every time you do a chained wall etc. it will automatically be grouped.
In the end what is your Objective?
ArchiCAD 9 onwards
Thank you. I am just trying to follow the tutorials.
9 REPLIES 9
Check the layer intersection group number if it's  assigned to 0 change it to any number other than 0.
AC 27 INT 5003 - AC 26 INT 6019 ( For MEP Purposes )
I think all are set to 1,  
That's because the thin skin at the composite edge I'm sure it's priority is higher than the rest, select the wall & check BM if higher then make it lower or duplicate and change the copy to be lower.
Mscott
Thank you it solved joint problem but walls are still separate created.
Lingwisyer
Guru
Toggle Groups (Alt + G)?
Though, given the nodes are black, it would appear that they are not grouped. You can create a group by making a selection then using the Create Group (Ctrl / Cmd + G) option.
Win10 | R5 2600 | 16GB | GTX1660
That is it.
Rectangular and chained walls are in fact single walls that are grouped.
Turning the grouping on/off will allow you select individual walls or the group that was drawn with the rectangle or chained command.
ryejuan
ArchiCAD 9 onwards
