wall tools creates separated walls
StarBoy
When I draw walls with rectangular, chained wall tools it creates separate walls not joint wall. How to fix it. Archicad 26
3 ACCEPTED SOLUTIONS
9 REPLIES 9
Mahmoud Qenawi
Check the layer intersection group number if it's  assigned to 0 change it to any number other than 0.
AC 25 INT 3002
I think all are set to 1,  
That's because the thin skin at the composite edge I'm sure it's priority is higher than the rest, select the wall & check BM if higher then make it lower or duplicate and change the copy to be lower.
AC 25 INT 3002
Mscott
Try heading to the View Menu > On Screen View Options and checking the option Clean Wall & Beam Intersections on
Thank you it solved joint problem but walls are still separate created.
Hero
Toggle Groups (Alt + G)?
Though, given the nodes are black, it would appear that they are not grouped. You can create a group by making a selection then using the Create Group (Ctrl / Cmd + G) option.
Win10 | R5 2600 | 16GB | GTX1660
That is it.
Rectangular and chained walls are in fact single walls that are grouped.
Turning the grouping on/off will allow you select individual walls or the group that was drawn with the rectangle or chained command.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
ryejuan
1. Go to Windows Menu choose Toolbars -> choose Arrange Elements
2. On the Arrange Elements Toolbar activate Auto Group then every time you do a chained wall etc. it will automatically be grouped.
In the end what is your Objective?
ArchiCAD 9 onwards
Thank you. I am just trying to follow the tutorials.
