working units set but still display incorrectly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-12-11
09:33 PM
2023-05-25
04:41 PM
Rubia Torres
H
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-10 12:52 PM
So, it looks like the issue is that the stair description text displays the measurements in 1/64" precision when its unit is set to inches (which is the default setting).
If you want this to follow your Dimension Unit settings instead (in project preferences - where you defined e.g. a 1/8" precision for length measurements), then you just have to go to the Description text settings of the stair, and change the unit from "inch" to "by Project Preferences".
I hope this helps you Heath, and also others who might stumble upon this issue in the future.
Regards,
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-03 04:49 PM
Can you reproduce the same in an empty project, or only in a specific one?
If you can, then could you create a really simple test file, and post it here, with a picture showing what the problem is?
Thanks,
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-03 10:06 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-07 04:44 PM
When there's a library update available for your version, you should get a notification about it (if you have notifications about updates turned on). You can also check it manually by going to 'Help>Check for Updates...'.
In either case, you will need to download and install the updates manually.
Regards,
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-07 06:38 PM
I just realized that my last reply was to the wrong post, but you answered anyway, thanks again. as soon as i find an example of the dimension issue, i'll send it along.
Heath
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-08 08:31 PM
Heath
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-09 02:15 PM
I am not quite sure where to look for this.
- Could you post a picture of this issue?
- Could you reproduce the same in an empty project, or only in a specific one?
- If you can, then could you create a really simple test file, and post it here (or send me the file in a Private Message)?
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-10 12:52 PM
Regards,
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-10 05:49 PM
Heath
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-14 08:18 PM
Ok, I don't have those options see screen shot. in fact, i can't see anywhere to even add the rise and run dimensions without manually adding it in the custom text field. this is a different model, but it's still AC@@ USA and it's still the standard profiles. what's going on here? I am also seeing the same issue with some of my windows. there is no place in my window selection settings to change this as far as i can see either.
Heath
