2023-06-12 06:55 AM - last edited on 2023-06-12 08:14 AM by Barry Kelly
The script works on its own. It's a simple GDL object, sits under the model element subtype and has a few parameters. All of which work (well ?)
I would like to insert this newly created GDL object into Param-O and make a nested parametric element.
Is there something I am not doing (right) - because of which my object doesn't show up when I try to load my object ?
2023-06-19 09:20 PM
Selecting placeable only, allows GDL objects to be visible in Param-O
2023-07-31 02:19 PM
You haven't given a lot of info. From what i guess it's not in in 3D? Then you can't see it in the 3D viewport. Param-o doesn't do 2D (you need to script it gdl)
2023-08-01 11:54 PM
I think., you've answered my question. I have a 2&3D GDL object. I wanted to try to distribute (using a series/ range) them using param-O. But when I do this., I lose the 2D aspects my GDL object. I don't think there is currently a way to circumvent this. Unless someone can direct me to a solution.
