Parametric design
About Rhino & Grasshopper and PARAM-O.
Grasshopper - ARCHICAD 23 Live Connection 4006 Compatibility update released
Minh Nguyen
Dear All,
I am happy to announce that we have released an update for the Grasshopper - ARCHICAD Live Connection for ARCHICAD 23.
The update delivers compatibility with the latest ARCHICAD 23 update (build 4006), as well as includes several stability improvements and fixes.
You can read the Release Notes and download the update installers here.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Edoardo B_
mnguyen wrote:
Dear All,
Best regards,
Minh
But it still doesn't fix the "Grasshopper is not running issue"...
MacBook Pro (15-inch, 2016) / CPU: 2,9 GHz Intel Core i7 quad-core / RAM: 16 GB 2133 MHz LPDDR3 / GPU: Radeon Pro 460 4 GB / macOS Big Sur (v. 11.6)
Minh Nguyen
Hi All,
For those who are interested in the issue mentioned by Edoardo, a fix for this defect will be included in ARCHICAD 23 update 2 (50xx). Hopefully this fix will help to eliminate this issue completely!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
