Problem installing the Archicad (v25) -grasshopper connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-06-19
11:55 PM
‎2022-09-23
03:48 PM
Oleksandra Vakariuk
Hi everyone,
I've installed the latest version of the connection. At the end of the installation I get the following message
even though I've installed the right package for the right rhino version (7)
Then, when I start AC to begin the connection, I can't found it where it should be.
Does anyone know how to solve this problem? I use the connection a lot!
Thanks
Solved! Go to Solution.
- Labels:
Rhino & Grasshopper
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-20 11:24 AM
I really don't know the answer as I don't have Grasshoper.
Just wondering if you had tried what the message said.
Could it be that you have a custom Work Environment and the commands just aren't there?
i.e. you may have to add them manually or switch to a standard Work Environment?
If you go to the Add-on Manager, does it show there that it is installed properly?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-20 02:25 AM
Did you then install the latest update of Archicad?
And if you already have it, did you re-install it as suggested in the message?
I ask simply because you didn't say if you did this or not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-20 10:39 AM
Hi Barry,
The connection was installed on the last Archicad 25 update. I've re-installed it now (I havn't done that when you asked), and the start button for the connection is still not there.
Erick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-21 09:53 AM
Hi again,
Thanks Barry for the tip on using the add-on manager function (first time for me). It was installed somewhere I never expected, as it used to be installed under file>interoperability. Now I can just start the connection from its "new" placement. Thanks a lot again Barry!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-21 10:24 AM
Awesome and well spotted.
I didn't think it might have installed in a different menu.
