Read more
Parametric design
About Rhino & Grasshopper and PARAM-O.
Profile modifiers
Adebar 799
Hi all,
Is it possible to change the standard value of a profile modifier to invidual?
If used complex profile from Grasshopper and defined different modifiers from grasshopper.
Everything worked fine. Today I've opened the script, connected to ArchiCAD and now every time I create a column with modifiers all modifier values are set to standard so they can#t be defined by grasshopper.
I didn't find anything in the profile Manager and I don't remember I changed anything since yesterday.
Regards Ramon
1 REPLY 1
derekjackson
I just had something similar - opened a file that was working previously, and all my complex profile were reverting to simple shapes. No errors in the script. I disconnected the Wall Settings component and reconnected it again, and it started working.
