Parametric design
About Rhino & Grasshopper and PARAM-O.
RHINO 7
I can see that Rhino 7 doesn't recognise ArchiCAD live connection. Is there a way to make it work or how shall I do it?
Frank
The Grasshopper-Archicad 24 Live Connection now supports Rhino 7:
https://graphisoft.com/downloads/addons/interoperability/rhino
The Grasshopper-Archicad 25 Live Connection is also coming soon, according to the web page.
29 REPLIES 29
Eduardo Rolon
Isn't Rhino 7 in Beta? I think the connection might require Rhino 6.
Eduardo RolĂłn AIA NCARB
AC27 US/INT -> AC08
another Moderator
It seems that they now release the Rhino 7 and it's not a BETA anymore.
Yes the connection requires Rhino 6. But I need to have in Rhino 7 so I just wonder if ArchiCAD was thinking of developping this for Rhino 7.
Eduardo Rolon
I don't see why not but they might take a little while in releasing the update.
AC27 US/INT -> AC08
another Moderator
davdelven
Before that, we should have already the update of the R6 compatible with the last AC built. Many of us apply the built due to necessary bug fixes, and we cannot use the R6 Grasshopper Live Connection.
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
leceta
Second AC24 update and gh connection is still only compatible with 3008.
Am I the unique one who thinks that GH connection doesn't deserve the consideration of a "professional tool"?
its buggy, it's not up to date with Archicad... this is so sad.
Urgently need Rhino 7 support!
Found that GH assembly lives in C:\Program Files\Rhino 6\Plug-ins\Grasshopper\ArchiCADConnection.gha
Copied it to C:\Program Files\Rhino 7\Plug-ins\Grasshopper and now it seems to work with Rhino 7
hi
do you see any chance that the Archicad - Grasshopper connection gets similar development and marketing focus like the one you find here listed as the second topic:
https://www.rhino3d.com/en/7/new/
I see the potentials by integrating the Rhino/GH environment with a BIM application crucial.
BR, Florian
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
furtonb
Based on the available information (right now), don't hold your breath...
https://archicad-talk.graphisoft.com/viewtopic.php?f=43&t=68012&start=10
https://discourse.mcneel.com/t/rhino-inside-archicad/93421
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
