Parametric design
About Rhino & Grasshopper and PARAM-O.
continious crashes
Ahmed_K
Hi mates , i'm using the Archicad GH connection since 1 month, every day i encounter several crashes when i try to exchange data between GH and Archicad, ( when working on GH only all is fine)
I have all archicad updates installed and latest GH connection , same problem with Rhino 5 and 6
Any help please ?
Archicad 27
Windows 11 professional
13 REPLIES 13
felcunha
Hello,
It happened with me until I reduce the screen resolution to 1920x1080. I suggest you try it if your screen resolution is higher.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Ahmed_K
Helle ! thanks for the reply
it crashes on 1920/1080 screen resoution and lower
Archicad 27
felcunha
Did you try to uninstall and reinstall your AC-GH connection ?
Ahmed_K
i tried, still crashes sometimes
Archicad 27
Ahmed_K
Any help please ??
Archicad 27
Which build of 22 are you using? I had the same issue when running on 4023 - I think 5003 fixes it.
Ahmed_K
I'm using Build 5009 ( frensh) , Rhino 6.11 with grasshopper included ( some plugins are installed like weaverbird, panneling ools, lunchbox )
Archicad 27
felcunha
Try to deactivate the other plugins, restart your computer and see what happens. I've have an info from a plugin editor who told me there could have a conflict between his plugin and AC-GH.
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello bouhmidage,
Has this issue been resolved? Do you still need help?
If it was solved, what was the solution?
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
