Project data & BIM
Annotation in schedule - Grid Snap
Yvonne
Grid snap keeps turning on when I go into annotate in a schedule - how do I turn this off?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
4 REPLIES 4
If you mean the actual grid snap where the cursor only snaps to grid positions (there is a little black dot that follows your cursor) - that shortcut is SHIFT+S will cycle through the 3 snap options, ALT+S is on/off.
If you mean the grey grid lines in the background then SHIFT+G turns them on/off.
Yes I meant the actual grid snap. I would have it turned off then when I go into annotate an elevation in a schedule it automatically turns on. Is there a way to have it not default to turning on?
I have never noticed the grid snap turning itself on, but then I rarely annotate in schedules.
I have noticed the grid lines turning themselves on in schedules, details, or when editing GDL, etc. Even sometimes when creating a new elevation.
I definitely always have the grid lines turned off and they do turn themselves on, and I know no way to stop it.
Maybe the 2 issues are related.
All I can suggest is be sure you are not accidentally pressing the keyboard shortcut, and have that toolbar handy so you can switch it off easily (or use the shortcut).
I have noticed the grid lines turning on as well but that doesn't bother me as much as the grid snap 😅  Thanks for the tip - I've got a shortcut for it so I can turn it off easily.
